Re: Fuel line for H
Posted by akb on March 08, 2008 at 22:28:12 from (75.161.132.54):
In Reply to: Fuel line for H posted by hsojman on March 08, 2008 at 16:09:49:
I used rubber line I even took off the sediment bowl ,to many problems with it plugging. I installed some angle fittings in tank then a ball shut off valve ,short section of hose then a see thru in line filter then rubber to carb.This solved all the fuel flow problems ect.
