Re: Farmall A Zenith Carb Problem
Posted by CT_Farmall on March 09, 2008 at 08:50:52 from (64.252.90.143):
In Reply to: Farmall A Zenith Carb Problem posted by Re: 460 is a knocking... on March 08, 2008 at 21:51:34:
teddy52food said: (quoted from post at 16:15:34 03/09/08) Why didn't you heat it with a torch until the flame shows a green color? Then let it cool and it will be loose. That is how to get the brass plugs out of a JD carb.
Tried that before I drilled it out with no luck.
