400 power steering hydraulic questions
Posted by Bob Frey on March 09, 2008 at 10:19:19 from (74.47.26.220):
I have Behlen power steering on my 400 and it works but not as as it should. I put a pressure guage on the outlet of the hydraluic control to see what oil pressure is available. My test set up, is a pressue guage just off of the supply point using a tee, and a hose with a valve in it that returns to the oil tank. With the valve open I get about 15 pounds and if I attempt to close that test valve, the pressure rises above the 60 pound maximum pressure for that guage I have. Any idea what pressure I should be looking for?
Second question. When it's cold out it takes some time before the hydraulic lift will work. I use Hy-Tran for the hydraulic system. Does anyone mix keroscene with the Hy-Tran in cold weather to thin it? Think it would help?
Thanks, Bob
