Re: 400 power steering hydraulic questions
Posted by Janicholson on March 09, 2008 at 11:57:20 from (66.173.50.49):
In Reply to: 400 power steering hydraulic questions posted by Bob Frey on March 09, 2008 at 10:19:19:
You need a gauge that reads 1500PSI to check that tractors hydraulic system. It may not go that high, but mid scale on a gauge is best accuracy. Do not put Kero in the oil. It will not assist the problem, and will contaminate the properties of the oil. Thinner oil is harder for a pump to make pressure with. The issue may be in the screen in the reservoir. If partially plugged, it will cause the weak action when cold. How long has the fluid been in the system? New fluid might just help a bunch. Be careful not to get air in the system when changing it. JimN
