Re: farmall h wont run
Posted by Patrick Martin on March 09, 2008 at 20:37:02 from (64.154.26.250):
In Reply to: Re: farmall h wont run posted by Chuck46 on March 09, 2008 at 20:33:37:
Check the coil. Just recently I had one that failed and tested perfect but would not send enough juice to the distributor.
