Re: 1486 Diff Lock
Posted by Iagary on March 10, 2008 at 03:44:19 from (67.55.192.138):
In Reply to: 1486 Diff Lock posted by DLJ on March 09, 2008 at 21:04:46:
The diff lock is to lock the rear end so that both wheels pull at the same time. Just as positraction does in a car.
If one wheel gets to spinning in a slick spot you can hit the diff lock to get the other side to help pull through and help from getting stuck.
You could do the same by tapping the brake on the wheel that is spinning. But if you tap to hard that wheel will stop and the other will spin.
Diff lock makes them both pull even.
Gary
