Re: 450 won't run no compression
Posted by Janicholson on March 10, 2008 at 09:58:19 from (199.17.6.122):
In Reply to: Re: 450 won't run no compression posted by kossuth on March 10, 2008 at 09:56:56:
It is possible for a gear to operate on the shaft with a sheared Key. Less likely, but possible. JimN
