You don't have to remove the tranny cover to replace the inner seal. You can remove the pto and get to everything that way. There are two long, fine threaded bolts that hold the retaining plate for the bull gear. With the pto cover off you can reach in and with a 9/16" wrench remove the bolts. I neat trick is to leave the back wheel on the axle and once you have the bolts loosened you can spin the back wheel and with the wrench on the bolts spin the bolts right out. I used a cherry picker and removed the axle with the wheel still on the axle. I was replacing the gasket between the axle housing and the rear end so everything came out together. Then you can get to the inner bearing and seal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
