Re: 450 won't run no compression
Posted by bedrock1234 on March 11, 2008 at 06:09:48 from (192.188.205.108):
In Reply to: 450 won't run no compression posted by HOSS357 on March 10, 2008 at 07:35:53:
Check to make sure the Distrubitor is turning.
Had an H that quit running one time, checked the distrubitor and it was not turning. I pulled the front cover and found the timing gear had come off, during a previous repair some where down the line they for got to I believe put in a cotter pin.
