Posted by Brownie450 on March 12, 2008 at 03:43:32 from (216.51.158.220):
In Reply to: Alternator issue posted by H fanatic on March 11, 2008 at 17:36:56:
Use 3/8 threaded rod for mounting the alternator to the bracket. I remember that we turned the mounting bracket upside down & had to lengthen the mounting holes about1/2 inch to get the proper belt alignment. We just used a hacksaw blade in the sabre-saw for making the holes longer. For the tightener-- use 2 pieces of 1/4 or3/8 inch thick by 3/4 inch wide steel slightly longer than needed & drill holes in both ends of both pieces[5/16 is large enough] & bend an off-set in one piece the thickness of the material[1/4 or3/8] to make the 2 pieces "flat" when bolted together. Use these bolted pieces like a hinged "V" to tighten the belt. I think we went to a 37 1/2 inch belt, also.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
