Re: DEGREEING CAM
Posted by Janicholson on March 12, 2008 at 06:12:24 from (199.17.6.122):
In Reply to: DEGREEING CAM posted by LIVIN LUCKY on March 12, 2008 at 03:39:32:
There are two methods I can think of. One is to use a special offset key in the drive custom made to place the desired advance/retard timing, the other is to use an adjustable drive pulley with a seperate hub and degree markings (unlikely to be available). If you have the specs for the cam, and a degree wheel for the front pulley, and a set of precision measuring tools, particularly a dial indicator, you can at least check the timing of the cam with all parts stock, and aligned as factory. If it is not reasonably close to the spec, (1/2 deegree)it will need adjustment to be powerful. JimN
