Re: H carb
Posted by rustyfarmall on March 12, 2008 at 07:58:36 from (209.152.78.71):
In Reply to: H carb posted by Andrew Z on March 12, 2008 at 07:45:22:
Andrew Z said: (quoted from post at 07:45:22 03/12/08) Also if it works youll have to change the throttle rod from the gov. to the carb. youll have to use the H part here to along with the carb. (the 300 one will be to short to reach the H carb)
Andrew
No. The governor tubes are specific to each tractor. The tube length on the M through 450 will be longer due to the increased length of the engine.
The tube used on the H through 350 is shorter, because of the shorter engine length.
You can put an M carb on an H or a 300 and still use the governor tube that is currently on the tractor.
