230 hydraulic problems
Posted by dozinhal on March 12, 2008 at 17:43:05 from (68.46.225.80):
I have a 230 w/fasthitch and a two bottom plow. We took the matchbox size block out of the plow and put it on top so the plows will now go in the ground. My mechanic moved the left hydraulic lever and watched me plow one round. After he left the tractor backfired through the carburetor and then I thought I busted a radiator hose. Then I realized it was hydraulic oil instead of water. The pressure knocked the clamp off the hydraulic hoses and the oil started leaking from somewhere up front.
What is wrong and why is it building up pressure? The system makes cavitation noises and the cylinder now goes all the way down until you can't see any of the ram.
Thanks. Hal
