Posted by Smith1000 on March 12, 2008 at 18:04:59 from (70.41.35.188):
I dropped the metal clutch housing cover on the M tonight to look at the clutch. It seems to be slipping and needs a new clutch. Oil and water ran out--mostly water. Kind of had a green tint to it like anti freeze may be mixed in. Would this be a bad seal or two?
From what I understand, the tractor must be split to replace the clutch as it has a 12 inch clutch.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
