Posted by Tractorfan1 on March 12, 2008 at 19:32:42 from (142.167.79.198):
In Reply to: Super M float stuck posted by Bob M on March 12, 2008 at 19:02:52:
Bob M said: (quoted from post at 19:02:52 03/12/08) Like Pete says a few raps on the float bowl with a wrench - or a block of wood - will usually free the float.
However if that doesn't do fix it you can drop the bowl to get at the float with the carb on the tractor. Simply remove the (4) cap screws that hold the bowl to the throttle body casting (7/16 wrench as I recall...). Then carefully lower the bowl.
Thanks to all for the help. I will try tapping the side of the bowl.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
