Re: 400 Hydraulic Pump (again)
Posted by mkirsch on March 13, 2008 at 11:55:48 from (64.80.108.52):
In Reply to: 400 Hydraulic Pump (again) posted by Paul in WI on March 13, 2008 at 11:33:03:
Paul, in a word, no. The pump drives the distributor, so unless you have a diesel that you've somehow managed to convert to direct-start, the pump must be turning in order for the tractor to run.
I suppose it could have lost prime, but it doesn't lose prime for no reason. Have you tried priming the pump through the little fill hole on top of the pump? Fill it up with the tractor not running, then start it up and see what happens.
