Posted by Bob M on March 14, 2008 at 12:11:27 from (151.190.254.108):
In Reply to: Super M steering posted by Larry D on March 14, 2008 at 10:10:31:
No embarrassment Larry! I had a similar problem when the nut unscrewed and dropped off the camshaft on my Super M. The cam gear then flopping around loose inside the timing cover beat the $)#*@ out of the threads on the end of the camshaft. Could not even get the nut started back onto it.
However couple of quality hours with a triangular jeweler's file and some patience I was able to clean up the mangled threads sufficiently get the nut to thread back on.
Depending on how bad the threads are beat you may be able to do the same to your pivot shaft...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
