Re: charging a positive ground system
Posted by IH2444 on March 14, 2008 at 18:47:43 from (209.209.140.20):
In Reply to: charging a positive ground system posted by rbuckel on March 14, 2008 at 18:32:55:
Positive or negative ground goes not matter if you hook the charger directly to the battery. Just hook the positive charger lead to the positive post on the battery and the negative lead to the negative post on the battery.
Use a 6 volt charger for a 6 volt battery of course. Or if selectable select the 6 volt setting on the charger.
Just do not let the negative charger lead/clip touch the frame or sheet metal or it will sparkum big time. if the battery is still hooked up.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
