Re: Super A Crank pulley
Posted by Hugh MacKay on March 15, 2008 at 09:26:11 from (209.226.106.51):
In Reply to: Re: Super A Crank pulley posted by Bob M on March 14, 2008 at 10:29:22:
Bob: The Super A is the same, and there is close to 3/4" of surface. The surface is unform size except for this 3/16" wide x 1/16" high rise on the inner end of pulley hub, that will be just behind the seal when installed. I did slide the seal on over that and it does fit snug to the surface, all positions. I can feel a bit of roughness on that surface though, thus I'm thinking the sleeve may be the best approach. That said, probably Don's suggested seal part number is the way to go. I see the part listing on CaseIH parts on line. I was also quite surprised to see the pulley still available new from CaseIH.
