Re: Farmall H locked engine
Posted by Janicholson on March 16, 2008 at 05:41:12 from (66.173.50.78):
In Reply to: Farmall H locked engine posted by Narrowfarm on March 16, 2008 at 05:30:54:
Two Shruggestions. One is to loosen the starter on the engine and wiggle it to see if the starter is jambed (they do that routinely) The fix is a clutch type drive from CaseIH Different and better.
The other is to make sure you are in High gear when "rocking" it. ATF in the cylinders seems to be better than WD40. But will work with it. Putting the crank snout into play with a 100 pound wt on a 2'
lever turning CW from the front will put force on it.
Bumping the starter (When not jambed) will also assist in freeing the engine. Don't give up, time is needed to get this done. JimN
