Re: Farmall A Magneto No Spark (Ideas Please?)
Posted by JT on March 16, 2008 at 11:22:14 from (70.12.157.6):
In Reply to: Farmall A Magneto No Spark (Ideas Please?) posted by dunniteowl on March 16, 2008 at 10:52:18:
Sounds like you have points that have corroded from sitting. That would be the first thing I check.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
