Re: Farmall A Magneto No Spark (Ideas Please?)
Posted by dunniteowl on March 16, 2008 at 11:27:45 from (4.230.129.242):
In Reply to: Re: Farmall A Magneto No Spark (Ideas Please?) posted by JT on March 16, 2008 at 11:22:14:
Thanks, JT, sounds like a good idea. The points are underneath the rotor coupling, correct? The part that has 3 screws holding it in place? The last time I was in there was some time ago, so that's definitely worth checking out.
Any other ideas from anyone else?
dunniteowl
Christopher in Bastrop, TX
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
