There is a hole in the trans case that the activating lever fits into when the pan is installed. It has a brass bushing in it. Make sure this is clean and has some lubricant, grease or white grease or anti sieze. That would be the only thing that would keep the brake pan from going on...other than the brake band not going over the drum. I think the band can only go in one way and the pin put throught it. Look at the pan and move the activating lever with your hand..does the band tighten the same in both pans? Does the lever return the band wide open?That'd be a start..good luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
