Re: How much is too wear on ring gear?
Posted by Hugh MacKay on March 17, 2008 at 16:38:31 from (216.208.58.147):
In Reply to: How much is too wear on ring gear? posted by Paul Shuler on March 17, 2008 at 05:20:46:
Paul: Go for the clutch type starter drive from CaseIH that Jim mentioned. They are light years ahead of the old bendix. I've had them on my SA and 130, close to 18 years now. They engage softer, will work on a ring gear that a bendix will never engage on.
Back 18 years ago I took both starters to a rebuilder. When they came home one starter worked beautifully on either tractor. The other starter would not engage on either tractor. Took them both off, Ah ha, a different type of drive that works. Back to the rebuilder. He said, "I only had one in stock, so sent over to the CaseIH dealer for the other, I'll replace that for you." I said, "The one I want you to replace is that damn bendix."
18 years ago, my ring gears were not in excellent shape, nor were they terrible. Similar to what you describe. My starters have not been off in 18 years. Since that time, I split both tractors for clutch replacement, but I did not bother to change the ring gear.
I also find, I never had a starter lock up with these clutch drives. No question they are better than what came new on the tractor. Because they engage softer, they don't damage ring gear teeth.
