Re: M brake drum wobbles????
Posted by riverbend on March 17, 2008 at 18:07:55 from (208.160.34.139):
In Reply to: M brake drum wobbles???? posted by mike a on March 17, 2008 at 17:25:41:
Why did you remove the brake band ?
The wobble might be as simple as the bolt that holds the brake drum is loose. Or as complicated as a busted differential housing ( ask me how I know...).
Greg
