Re: 706 pinion bearing,
Posted by the tractor vet on March 18, 2008 at 07:26:49 from (99.167.216.34):
In Reply to: 706 pinion bearing, posted by farm-al on March 17, 2008 at 20:00:52:
IF it was me i would be looking for a used bearing cage then come the set up of the ring and pinion and bearing preload . As for the new style i have never in all the 06 seires tractors had to replace one so here i do not know . I have had to replace pinion bearings and a couple ring and pinions over the time that i worked on them but never got a new set up . Luckly i have the special tools to do this . IT also helps to get the parts out of a parts tractor along with the shims .
