Charles, Look for a junked 715D, all you need to test glow plugs is a test light. Pull wire from plug, hook light to a hot wire and ground threw plug. If it lights the plug is good. To use a glow plug meter you need to check them one at a time, it will not indicate one bad plug. Good luck, Chuck
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
