Correct for Glow plugs in parallel circuits. Some on some IH and others are series plugs like old Christmas tree lights, and are definitely not grounded internally. These need to be checked (when none work because one is bad) by testing from the supply terminal to the ground terminal with a volt meter while someone is pushing the buttom. The bad plug will read about battery voltage across the blown filiment. The good plugs will read near nothing. JimN
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
