Posted by Owen Aaland on March 18, 2008 at 15:33:54 from (65.161.86.122):
In Reply to: starting my W-6 posted by mikey c on March 18, 2008 at 11:06:00:
In addition to internal started problems, a poor connection can cause the problem you are describing. A poor connection will cause heat to be generated when the current passes through it and the heat can expand the parts making a better connection so that it will again crank faster. After cranking for a little bit, feel the connections to see if any have gotten warm.
One other thing that can cause this is antifreeze contamination of the oil. I had this happen on a 686 diesel. The engine would be so tight that the started could not turn it over but if you used a bar to turn the engine just slightly it would then crank just fine. As soon as it sat for a few minutes it would be seized again.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
