Re: 560- Water in hytran
Posted by Hugh MacKay on March 18, 2008 at 16:06:46 from (64.228.11.161):
In Reply to: 560- Water in hytran posted by BrianDuluth on March 18, 2008 at 14:50:13:
Brian: Most of the water runs down the gear shift lever right into the transmission. I took a section of very heavy inner tube, about 6" x 8", cut small hole in middle, slid it down over shift lever right to the spring, then used a glue around the inner tube and shaft. Let the tube ends hang down over the tower to run the water off. Some have lasted one season, and I have one that has lasted 10 years. Not perfect, but it helps.
I've seen guys use a long plastic sleeve, length of shift lever, right down to the base. It works well. With short gear shift levers like SA, I just put a plastic bucket over the shift lever. That shift lever catches a lot of water and the longer they are, the more they catch.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
