Posted by pvia on March 20, 2008 at 10:19:02 from (75.170.98.226):
Hello, I installed the original mag and followed the manual instructions. I turned it over by hand to #1 TDC and then pulled the mag back from the mount and the impulse snapped just like the book says it is suppose to. The tractor fired right up. The next time I went to start it it would sputter for a few moments and quit. I rolled it by hand back up to #1 TDC and pulled the distributor cap off and the rotor was between the #2 and #1 posts and not lined up with the #1 post anymore and did not snap when removed from the mount. I also noticed after the mag was removed and turned by hand that there was very little spring tension from the impulse for the #2 cylinder, it had tension on all 4 of the cylinders when I installed it. The other cylinder firing locations have good tension. If the impulse has gone bad for the #2 cyl will it affect the overall timing. When I installed the 12volt distributor from my SMD in it she fired right up. Any ideas as to what is going on here? Thanks, Phil
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
