Re: 47 MD Magneto
Posted by gene bender on March 20, 2008 at 12:51:52 from (67.55.226.69):
In Reply to: 47 MD Magneto posted by pvia on March 20, 2008 at 10:19:02:
When you get to TDC the mag fires. Next time pull the plugs so it turns easy then when turning over with the crank you can see when the mag rotor lines up and gires. Mark a place on the mag where the towers are then as you turn it over with the crank you will see it line up and get ready to fire. Now you mite have the rotor off a tooth of so. You can turn the mag over without being in the tractor that way you will see if the rotor is lined up with the cap.
