Re: Farmall 560 hydraulics
Posted by Hugh MacKay on March 20, 2008 at 11:03:35 from (216.208.58.152):
In Reply to: Farmall 560 hydraulics posted by Gary Hutchinson on March 20, 2008 at 10:18:53:
Gary: You don't mention if having freezing temperatures. If it happened sudenly, and in freezing temperatures, my reaction is water in the system and it froze in the filter. My experience, that will stop 560 hydraulics PDQ.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
