Farmall 560 hydraulics
Posted by Gary Hutchinson on March 20, 2008 at 10:18:53 from (192.236.22.173):
My Farmall 560 has suddenly gone "weak". The last
time I used it everything was fine. I started it up and tried to raise the snowblower attachment
on the quick hitch and it couldn't lift it. I
plugged a gauge into all three of the valve
outputs and they're only reading 1200 p.s.i. The
suggestions I've heard so far are bad pump, bad
pressure releif valve, low oil in the hydraulic
system, or clogged filter. Any other opinions?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
