Re: 656/1967/5 speed with TA/gas/263
Posted by bc on March 20, 2008 at 21:56:39 from (66.140.173.77):
In Reply to: 656/1967/5 speed with TA/gas/263 posted by Jerry Gilliam on March 20, 2008 at 18:16:19:
Bummer.
I think this is one that you can remove the shifter and top cover off the top of the tranny and inspect the gears. In fact you can see some of the gears by removing the large bullplug where you fill the hytran. Maybe stick a swivel mirror in there and use a flashlight. I believe the 4th gear is a larger one towards the rear. I can't tell from the drawing but one shaft has a sliding gear that works for both 4th & 5th. If you have 5th then it is not that gear.
If you have any metal chips laying around in the bottom of the tranny, you may want to change your fluid to keep any metal pieces out of the hydraulics. To properly check the tranny, you probably have to drain it anyway. Then run a magnet around the bottom to get any loose metal.
I'll let someone who has had one of these apart tell you more.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
