Re: Farmall 560 hydraulics
Posted by Gary Hutchinson on March 21, 2008 at 05:55:46 from (192.236.21.237):
In Reply to: Farmall 560 hydraulics posted by Gary Hutchinson on March 20, 2008 at 10:18:53:
I'm definitely going to follow up on what you
are saying about the water contamination and
frozen filter. I'm in central Wisconsin and it
has been a consistently cold winter. The tractor
never sees the light of day as it is in a shed.
Even when the temps get above freezing during
the day, it is in the 20's at night and it is
easy to imagine that filter isn't getting a
chance to thaw out. Thanks guys for the advice.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
