Re: HYDRAULIC HELP!
Posted by ChrisAS on March 21, 2008 at 11:34:48 from (75.170.124.5):
In Reply to: HYDRAULIC HELP! posted by David Goode on March 21, 2008 at 10:55:01:
If you don't have the lift on 2 way the just goes back to the tank and none to the other side of the cylinder. The problem you is hard to stop.
We use to add an other tub tank to the fill port that was about a quart just to hold the air from the back force.
