Re: HYDRAULIC HELP!
Posted by Owen Aaland on March 21, 2008 at 16:50:15 from (65.161.86.122):
In Reply to: HYDRAULIC HELP! posted by David Goode on March 21, 2008 at 10:55:01:
The oil returning to the oil fill hole is the problem. As you retract the cylinders you are displacing an amount of oil equal to the volume of the cylinder rams. This is the same as adding oil to the reservoir. As the additional oil returns to the reservoir, air must be displaced to allow the oil in. The air coming out will carry some of the oil with it causing the problem you are having. Plumbing the return into the drain hole will cure your problem.
