Re: IH 584 white smoking?overfueling?timing out?valve tim...
Posted by DougM on March 21, 2008 at 20:14:27 from (207.200.149.10):
In Reply to: IH 584 white smoking?overfueling?timing out?valve timing out posted by Mad Harry on March 19, 2008 at 16:52:10:
MH, If the compression is indeed good, then it sounds like a Injection pump timing issue, Acrid white smoke is an indication of very late injection timing.
There were 3 engines in this series from Neuss the D155,(3cyl),D206(4cyl), & D310(6cyl). They all used the same inj pump timing gear. There should be a bunch of different numbers stamped on the gear( something like 1 thru 8). One of these #'s will be for your engine in its application. Once the number is aligned with the mark on the idler gear, then the pump can be timed.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
