farmall 230 rear clunk noise
Posted by BLK ANGUS on March 21, 2008 at 21:39:39 from (75.162.158.156):
Farmall 230 clunk type noise in one of the rear wheels. It sounds as if the wheel is slipping on the axle when it turns around but all the bolts are tight and the two key ways for the wheel and the mating u shaped connector are all tight and in place. The bolt from the wheel to the rime are also ok. I'm thinking it is inside the rear end and is being transmitted to the wheel from the axle. I can not detect any jerks as the axle turns but it does seem to clunk in the same position as the wheel goes around. sometimes it will clunk twice. It is more noticeable in a turn. I have never been inside of one of these and could use some help if anyone has some ideas.
