Once again, Good old experience is worth it's weight in gold! Thanks for all your advice and helps. I started with the rim bolts. They tested out at 40 lbs torque. I tightened them to 95 ft lbs. The U connectors on the axle/wheel were at about 50 ft lbs. They also were re tightened to 95 ft. lbs. torque. The other wheel has very tight rim bolts. More than 95 lbs but I didn't determine how much. But the u connector was at about 50 lbs, just like the side with the clunk. It was also re tightened to 95 lbs. I them jacked up the frame holding the axle watching for any axle movement. I saw none. I blocked it up and turned the wheel by hand. Herd no noises. If this was proving the working inside the rear end, then I could detect nothing.(but the only clunk from before was with the weight of the tractor and a harrow on the wheels. With the harrow remove and on pavement instead of dirt,I could barely detect it before). I removed the lift and took it for a test ride. No clunking. I bought this tractor in disassembled in pieces in a bunch of boxes years ago. The transmission and rear end were the only things in tact. The engine needed lots of work but has been mostly fixed and is working fine now.It has other issues that still need to be dealt with, but I have no real info other than what I can glean at out Case Dealership here in town. It seems that tightening these bolts could very well have corrected the clunk, But how much should they be tightened? What I really need is some good info on this tractor. It's a cool tractor and works very well. Thanks again for your help Rex
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
