Re: HELP!! 504 Hydraulic System Noise
Posted by the tractor vet on March 22, 2008 at 08:30:16 from (76.212.239.62):
In Reply to: HELP!! 504 Hydraulic System Noise posted by Andy Whitehead on March 22, 2008 at 08:08:22:
I think that ya have way more pump then the system can handle . First off the filter when new really made to only handle around 14 GPM the flow divider does not know where to send the extra oil . Ya i know that ya can put the bigger pumps on them BUT did upgrade the oil cooler ?? are you using the extra flow . There is a lot to take into account when adding more flow . A good 12 GPM pump will do a lot. Another thing is that the passage ways that are cast into the system have not changed in size so now instead of flow you have Extra pressure and this is making the pressure relief work overtime.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
