Try taking off signal line on hyd pump, unscrew fitting and you will find a orfice-screen this needs to be removed to clean. If you have oil running out when you remove fitting chances are the orfice is clean. Also there is a signal check in priority remote that could broken worn/missing and there is a repair kit for this. There is 2 orfices in casting on hyd pump housing that can cause low or no pressure on these systems.If you have a local Case dealer that has online parts lookup you will find the location of these orfices. Good luck
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
