Posted by Randy-IA on March 22, 2008 at 19:07:07 from (207.177.83.88):
Hi All , The transmission rebuild has moved to the final drive too . I'll probably have to replace the differential and axle bearings because of the crud that was in the oil . I might take the cheapskate way out for the the axle and bullgear pinion bearings and take them out of a parts tractor instead of buying new ones . I don't know yet till I get everything apart . I have a question about the reverse idler shaft . It has pits in it from rust . It only had minor play in the old bushings but I bought new bushings anyway ( Sticker Shock !! ) . I wasn't surprised at the cost of the bearings but the bushings I was ! The shaft was plugged with crud and I got it cleaned out as good as I can . I'm thinking of soaking it in carb cleaner overnight to be sure it's clean on the inside . I'm not to concerned about the rust pits . I feel that they will just hold that much more oil for lubrication . I was curious as to what everybody else thought about it ? I've shined it up with emery cloth . I still have to check the clearance of the new bushings . Hopefully it'll be snug without needing honing or to loose . One more question about the clutch throw out bearing . This one is tight . So is it OK to wash it off in a parts washer with commercial cleaner ? I'm not sure if it has any rubber seals in it I need to be concerned about . I haven't decided yet whether or not I'm replacing the clutch parts . I don't want to split the tractor to remove the flywheel to turn it and it needs turning if I put in a new disc . It has it's fair share of heat cracks . Thanks to all for any opinions ! ...Randy
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
