Posted by Mike CA on March 22, 2008 at 23:26:59 from (75.31.167.105):
In Reply to: Well, here it is posted by Mike CA on March 22, 2008 at 22:48:32:
gots-2-go said: Are you still looking for a dist. manifold heat shield?
Yes, but not actively. The last one I saw on Ebay went for $153!! I have bigger priorities, considering my currently manifold would need quite a bit of work to get it usable for the shield.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
