Re: Cranking a F-20
Posted by RAW in IA on March 23, 2008 at 11:23:27 from (12.215.87.124):
In Reply to: Cranking a F-20 posted by Va Gasman on March 23, 2008 at 10:30:09:
If it is working right you don't spin the crank. Start with it atothe bottom of th arc and pull up slow. It should start wwhen the impulse clicks. We usually choked it for the first pull, then push the choke off and it should take off. If it doesn't die when retarding the spark lever completely, some mags have a flat spring son the side you push against the case to kill it.
