Re: #2 fouling plugs in a Farmall M
Posted by steelfronts on March 23, 2008 at 17:09:02 from (24.236.223.115):
In Reply to: #2 fouling plugs in a Farmall M posted by Steve in WPa on March 23, 2008 at 14:25:24:
When you remove the plugs does #2 look different than the rest? What does it look like ? Is it wet . If you put that plug in a different cly will it work and foul the new plug? Maybe a bad wire or cap. Try to isolate the problem or move it to a different cyl then it'll be identified. Carbs dont discriminate its probably electrical
