Re: Will a selective lift control unit
Posted by mkirsch on March 24, 2008 at 06:21:33 from (64.80.108.53):
In Reply to: Will a selective lift control unit posted by Janicholson on March 24, 2008 at 06:10:25:
Vito,
The "period correct" way would be to remove the loader, or at least unplumb it, and plumb in the xmas tree valve.
Farmers had a lot more time back then.
You would definitely need a way to shut flow off to the valve to use the loader, and a way to shut flow off to the loader to use the valve.
Here's a selector valve that'd do the trick:
http://www.surpluscenter.com/item.asp?UID=2008032408265077&item=9-004-A&catname=hydraulic
However, it's $62.99, pretty expensive. If you're going to spend that much, why not get a one-way spool valve so you can run BOTH at the same time:
http://www.surpluscenter.com/item.asp?UID=2008032408265077&item=930-A&catname=hydraulic
