Re: Farmall H engine that was stuck. Number info
Posted by El Toro on March 24, 2008 at 17:46:27 from (64.12.116.73):
In Reply to: Farmall H engine that was stuck. Number info posted by Narrowfarm on March 24, 2008 at 16:42:03:
You should have the sleeves measured for wear. They may need to be replaced if the wear limits are exceeded. Have the crankshaft measured too.
If the cam bearings are worn they should be replaced since they determine good oil pressure.
Hal
