Start with holes in the manifold bein' the problem. Read "massive amounts of unfueled air." Those 123s don't take much choke to start, and won't run well for long with any choke at all, no matter how cold.
If you've got her to run with choke, she's gettin' too much air somewhere. You need to have a good manifold with no leaks. It needs to be mounted to the head with good gaskets torqued down. You need a good gasket between the top of the carb and the neck of the manifold. I don't like bringin' it up, 'cause it's costly to fix, but might you have a crack in the head? If all the easy things are in order, it might pay to have the head magnafluxed, but I'd think a leak that bad would be obvious to the eye.
If your carb is good to go, these are the only places (apart from the head gasket, but then you'd be havin' other, more serious problems) that you could be leakin' vacuum.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
